Taskalfa 300ci command center not loading and other strange things
  • Thorsten_300ci
    • May 2018
    • 8
  • Kyo fan
    • Dec 2013
    • 368
    Re: Taskalfa 300ci command center not loading and other strange things
    You should do U021 to reset previous settings. Print the event log with U000 first, since it will wipe it. You can move the fax card, but you also need to move the fax memory from main pwb, since it will code out without it. Enter fixed network settings manually, reset the device, and see if it works. These oldies don't support bonjour, so don't bother. Just download driver for IOS and install. For Windows, get KX driver only.
    • craigster
      • Apr 2016
      • 201
      300ci is the most problem child we ever sold. we replaced all but a couple.
      My advice is to push it out the door and replace with the newer models.
      good luck.
        • 22917
        I think I would connect my laptop directly via crossover cable, to completely remove your network as a potential cause. =^..^=
        • Thorsten_300ci
          • May 2018
          • 8
          Sorry for the late reply
          The issue was an active IPv4 Filter, which allowed only one IP-Address to connect to the 300ci.
          Even prior to my initial post I try recreating the old network range to connect to it that way with no luck.
          i ended up using IPv6 where no IP Filter was configured and was able to connect to the 300ci this way and could perform all necessary changes.
          Now all is working.
          • Ricky965
            • Mar 2008
            • 36
            We have one of those. The ethernet quit on it's own and other little things. Upgraded the firmware and it restored everything. working ok now. Might try that,.
