problem with fs-2000d
  • masb23
    hey i have a problem with this printer because is jaming under registration roller i alredy replace all boards all clutches ,rollers,cassette but still jaming somebody can help me????
  • termacadon
    IT goofball
    • Oct 2008
    • 66
    Does it reach the registration roller? Does it stop before it? Does it crease at the roller?
    All else you have to change is the switches and update it to the latest firmware.
    • masb23
      i alredy replace the registration roller and still jaming
      • termacadon
        IT goofball
        • Oct 2008
        • 66
        Yes, but read the question.
        Have you replaced the switches and updated the firmware?
        • masb23
          yes the paper stop just 1 mm after pass the registration roller and what switches need to replace???
          • termacadon
            IT goofball
            • Oct 2008
            • 66
            What firmware version do you have on this machine?
            I meant sensors...sorry... its late over here!
            • masb23
              version firmware 158.05-28 what sensors???? registration sensors comes in the main pcb and i alredy replace the main pcb
              • termacadon
                IT goofball
                • Oct 2008
                • 66
                S2F8_3000.009.001, engine S2F8_1000.010.001
                update it to this one. I cant see that there would be anything else wrong... You replaced the boards, reg roller etc.
                It would not possibly be a paper size issue? I know i came across a few problems where they would have the machine set to A4 and print to legal size paper, then the machine would jam cause the sensor timing is out.
                Im confuzzed otherwise my friend. Does anyone else have an opinion?
                • masb23
                  still have a problem
                  hey men i alredy upgrade the firmware version and still jaming i replace everything boards sensors rollers and still jaming anybody have a solution???
                    • 30221
                    jam problem
                    does it jam runnning in the bypass? or just the cassette tray?
                    • masb23
                      just from cassette from by pass is runing ok
                        • 30221
                        Printer jam
                        replace part 302f994030 feed drive
                        most likely a clutch problem should be under warranty
                        • masb23
                          i replace all drive with clutches and gears
                          • techman
                            • Dec 2007
                            • 49
                            make sure the mylar strips near the registration section is not bent also the springs that hold the upper and lower registrations roller togethermay be out of place or stretched out if the springs are not tight the paper wont feed corectlly try replacing the springs.
                            • masb23
                              i already did all replace the spring registration roller and maylars and still jam i think maybe can be the frame but idk
