Kyocera 307ci any good?
  • campy
    • May 2012
    • 315
    I have a customer that's looking for 3 of these and wonder if they have been any good. Any info will be greatly appreciated.
  • tmaged
    Owner/Service Manager
    • Oct 2008
    • 1890
    Re: Kyocera 307ci any good?
    No problems at all.
    Hope that helps !
    -Tony
    www.dtios.com
    Become a fan on Facebook
    • Paper_Jam
      Expecting a call.
      • Jun 2007
      • 101
      We've had issues with lines on the copies multiple times, you can clean the drum and charge roller but most of the service calls I've run on them has been for lines.
      • campy
        • May 2012
        • 315
        How often do the lines appear and is it time consuming or hard to clean the drum and charge roller?
        • ntbann
          • Jan 2012
          • 628
          Open front cover, open drum cover, pull out drum, remove charge, clean with water, and reassemble.
          • jper34
            • Sep 2011
            • 225
            I've had really good luck with these copier, nothing heavy duty volume, tho..but very easy to service, and toners are pretty good priced..
            I'm relly becoming a Kyocera fan, as far easy to service, and no crazy error problems..nor any hard drive issues, so far..
            Good Luck !
            Jaime
