Kyocera KM-4050 screen calibration
  • mantis01
    • Mar 2019
    • 9
    I have a Kyocera KM-4050 the the touch screen keeps losing its calibration usually 2 or three times a day.
    • 23010
    Re: Kyocera KM-4050 screen calibration
    There is ... and don't bother. You'll need to replace the touchscreen and foams, the calibrate the screen just once. =^..^=
      Hey BC.... the Ricoh's had bad problems with the TS for a while... they were Toshiba's If I recall properly..
      What brand of TS are these ... do you know?
        • 23010
        They weren't tagged in any way that I recognized. It was during the same time when Konicas and Kyoceras all had rashes of bad screens. I'm sure they all came from the same source. Hans was repairing them for a while ... do you know a manufacturer of the touch screens Hans?
        It was the conductive adhesive that was the problem. The end of the ribbon cable would change color ... I can't remember how ... but you could tell immediately that it was poorly attached. If you pressed down hard on the connection point it would work for a little while, but not long enough to go to the trouble to remove it for that. =^..^=
        From the database:
        Touch panel is unresponsive or registers ~1" to the left or right of the button. Copies OK. Poor connection between tablet and ribbon cable. Tape turns visibly yellow, as an indication. Replace tablet (302GR45051), foam x2 (2BJ25280), and foam x2 (302GR05310). Run simulation U201 to initialize the touchscreen. Touch each crosshair at the three positions, Start.
        • kjg
          • Mar 2009
          • 112
          Back when we were experiencing these failures frequently, I researched and ordered the Z-axis conductive tape that connects the ribbon cable to the edge of the glass. It needed to be heated and removed, contacts cleaned and new tape applied and then the ribbon re-mounted. All in all it could be done in about 10-15 minutes. We did dozens of these repairs and they lasted until retirement of the machines.
          Z-axis tape only conducts vertically. not in X - Y axis. it has multiple uses.
          3M 9703 Z-axis tape. For anyone who breadboards, it's a good temp way to experiment with SMT IC's.
