TA 420i - slow printing from Unix
  • KOBA
    • Mar 2019
    • 16
    #16
    Re: TA 420i - slow printing from Unix
    I've just tried this PPD and the speed of the printing is the same - sloooow... so nothing changed
    EDIT:
    one of the printing files was printed faster, but after one 2sided page there was a blank one
      • 30477
      #17
      Only option would be to try an HP laserjet ppd as kyocera's emulate hp
      • KOBA
        • Mar 2019
        • 16
        #18
        Thanks for answer, but as for HP driver it won't work (we have additional hardware like finisher/bigger paper casette).
        I've found one option somewhere on the internet for kyocera printers - setting an addditional option for printer
        Code:
        lpstat -v
        lpadmin -p <printer_name> -o pdftops-max-image-resolution-default=300
        Hope this will change the printout time..
        • KOBA
          • Mar 2019
          • 16
          #19
          Hello again!
          Kyocera got new printer drivers for Linux KyoceraLinux-Phase6 (https://cdn.kyostatics.net/dlc/pl/dr...190626.tar.zip)
          So I got them up and running on Linux workstations, but there is a strange error when I try to print something - "Filter failed".
          Job from error_log:
          Code:
          E [date] [Job 1] Job stopped due to filter errors; please consult the error_log file for details.D [date] [Job 1] The following messages were recorded from 08:05:23 to 08:05:26
          D [date] [Job 1] Adding start banner page "none".
          D [date] [Job 1] Queued on "Kyocera_BOK_420i" by "LinuxUser".
          D [date] [Job 1] Auto-typing file...
          D [date] [Job 1] Request file type is application/pdf.
          D [date] [Job 1] File of type application/pdf queued by "LinuxUser".
          D [date] [Job 1] Adding end banner page "none".
          D [date] [Job 1] time-at-processing=1562997923
          D [date] [Job 1] 3 filters for job:
          D [date] [Job 1] pdftopdf (application/pdf to application/vnd.cups-pdf, cost 66)
          D [date] [Job 1] pdftops (application/vnd.cups-pdf to application/vnd.cups-postscript, cost 100)
          D [date] [Job 1] /usr/lib/cups/filter/kyofilter_F (application/vnd.cups-postscript to printer/Kyocera_BOK_420i, cost 0)
          D [date] [Job 1] job-sheets=none,none
          D [date] [Job 1] argv[0]="Kyocera_BOK_420i"
          D [date] [Job 1] argv[1]="1"
          D [date] [Job 1] argv[2]="LinuxUser"
          D [date] [Job 1] argv[3]="Bez tytułu1"
          D [date] [Job 1] argv[4]="1"
          D [date] [Job 1] argv[5]="InputSlot=PF700C PageSize=A4 job-uuid=urn:uuid:8b2974ee-af8c-3dbb-55f6-e33484f7534f pdftops-max-image-resolution=300 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1562997923 time-at-processing=1562997923 document-name-supplied=xurMV8"
          D [date] [Job 1] argv[6]="/var/spool/cups/d00001-001"
          D [date] [Job 1] envp[0]="CUPS_CACHEDIR=/var/cache/cups"
          D [date] [Job 1] envp[1]="CUPS_DATADIR=/usr/share/cups"
          D [date] [Job 1] envp[2]="CUPS_DOCROOT=/usr/share/cups/doc-root"
          D [date] [Job 1] envp[3]="CUPS_FONTPATH=/usr/share/cups/fonts"
          D [date] [Job 1] envp[4]="CUPS_REQUESTROOT=/var/spool/cups"
          D [date] [Job 1] envp[5]="CUPS_SERVERBIN=/usr/lib/cups"
          D [date] [Job 1] envp[6]="CUPS_SERVERROOT=/etc/cups"
          D [date] [Job 1] envp[7]="CUPS_STATEDIR=/var/run/cups"
          D [date] [Job 1] envp[8]="HOME=/var/spool/cups/tmp"
          D [date] [Job 1] envp[9]="PATH=/usr/lib/cups/filter:/usr/bin:/usr/sbin:/bin:/usr/bin"
          D [date] [Job 1] envp[10]="SERVER_ADMIN=root@SP11581"
          D [date] [Job 1] envp[11]="SOFTWARE=CUPS/2.1.3"
          D [date] [Job 1] envp[12]="TMPDIR=/var/spool/cups/tmp"
          D [date] [Job 1] envp[13]="USER=root"
          D [date] [Job 1] envp[14]="CUPS_MAX_MESSAGE=2047"
          D [date] [Job 1] envp[15]="CUPS_SERVER=/var/run/cups/cups.sock"
          D [date] [Job 1] envp[16]="CUPS_ENCRYPTION=IfRequested"
          D [date] [Job 1] envp[17]="IPP_PORT=631"
          D [date] [Job 1] envp[18]="CHARSET=utf-8"
          D [date] [Job 1] envp[19]="LANG=pl_PL.UTF-8"
          D [date] [Job 1] envp[20]="PPD=/etc/cups/ppd/Kyocera_BOK_420i.ppd"
          D [date] [Job 1] envp[21]="RIP_MAX_CACHE=128m"
          D [date] [Job 1] envp[22]="CONTENT_TYPE=application/pdf"
          D [date] [Job 1] envp[23]="DEVICE_URI=socket://192.168.0.203:9100"
          D [date] [Job 1] envp[24]="PRINTER_INFO=Kyocera TASKalfa 420i BOK"
          D [date] [Job 1] envp[25]="PRINTER_LOCATION=Piastowska 11a BOK"
          D [date] [Job 1] envp[26]="PRINTER=Kyocera_BOK_420i"
          D [date] [Job 1] envp[27]="PRINTER_STATE_REASONS=none"
          D [date] [Job 1] envp[28]="CUPS_FILETYPE=document"
          D [date] [Job 1] envp[29]="FINAL_CONTENT_TYPE=application/vnd.cups-postscript"
          D [date] [Job 1] envp[30]="AUTH_I****"
          D [date] [Job 1] Started filter /usr/lib/cups/filter/kyofilter_pre_F (PID 4304)
          D [date] [Job 1] Started filter /usr/lib/cups/filter/pdftopdf (PID 4305)
          D [date] [Job 1] Started filter /usr/lib/cups/filter/pdftops (PID 4306)
          D [date] [Job 1] Started filter /usr/lib/cups/filter/kyofilter_F (PID 4307)
          D [date] [Job 1] Started backend /usr/lib/cups/backend/socket (PID 4308)
          D [date] [Job 1] pdftops - copying to temp print file \"/tmp/010d25d2f0ef1\"
          D [date] [Job 1] STATE: +connecting-to-device
          D [date] [Job 1] Looking up \"192.168.0.203\"...
          D [date] [Job 1] hrDeviceDesc=\"TASKalfa 420i\"
          D [date] [Job 1] ATTR: marker-colors=none,none
          D [date] [Job 1] ATTR: marker-names=\'\"TK-725\"\',\'\"Waste Toner Box\"\'
          D [date] [Job 1] ATTR: marker-types=toner,waste-toner
          D [date] [Job 1] ATTR: marker-levels=6,-1
          D [date] [Job 1] new_supply_state=0, change_state=ffff
          D [date] [Job 1] STATE: -developer-low-report
          D [date] [Job 1] STATE: -developer-empty-warning
          D [date] [Job 1] STATE: -marker-supply-low-report
          D [date] [Job 1] STATE: -marker-supply-empty-warning
          D [date] [Job 1] STATE: -opc-near-eol-report
          D [date] [Job 1] STATE: -opc-life-over-warning
          D [date] [Job 1] STATE: -toner-low-report
          D [date] [Job 1] STATE: -toner-empty-warning
          D [date] [Job 1] STATE: -waste-receptacle-almost-full-report
          D [date] [Job 1] STATE: -waste-receptacle-full-warning
          D [date] [Job 1] STATE: -cleaner-life-almost-over-report
          D [date] [Job 1] STATE: -cleaner-life-over-warning
          D [date] [Job 1] new_state=0, change_state=ffff
          D [date] [Job 1] STATE: -media-empty-warning
          D [date] [Job 1] STATE: -door-open-report
          D [date] [Job 1] STATE: -media-jam-warning
          D [date] [Job 1] STATE: -input-tray-missing-warning
          D [date] [Job 1] STATE: -output-tray-missing-warning
          D [date] [Job 1] STATE: -marker-supply-missing-warning
          D [date] [Job 1] STATE: -output-area-almost-full-report
          D [date] [Job 1] STATE: -output-area-full-warning
          D [date] [Job 1] backendWaitLoop(snmp_fd=7, addr=0x55c753278938, side_cb=0x55c751d25000)
          D [date] [Job 1] PID 4304 (/usr/lib/cups/filter/kyofilter_pre_F) exited with no errors.
          D [date] [Job 1] PID 4305 (/usr/lib/cups/filter/pdftopdf) exited with no errors.
          D [date] [Job 1] Printer make and model: Kyocera TASKalfa 420i
          D [date] [Job 1] Running command line for pstops: pstops 1 LinuxUser \'Bez tytułu1\' 1 \'InputSlot=PF700C PageSize=A4 job-uuid=urn:uuid:8b2974ee-af8c-3dbb-55f6-e33484f7534f pdftops-max-image-resolution=300 job-originating-host-name=localhost date-time-at-creation= date-time-at-processing= time-at-creation=1562997923 time-at-processing=1562997923 document-name-supplied=xurMV8\'
          D [date] [Job 1] Using image rendering resolution 300 dpi
          D [date] [Job 1] Deactivated compression of pages in Ghostscript\'s PostScript output (\"psdebug\" debug mode or Kyocera/Utax printer)
          D [date] [Job 1] Running command line for gs: gs -q -dNOPAUSE -dBATCH -dSAFER -sDEVICE=ps2write -sOUTPUTFILE=%stdout -dLanguageLevel=3 -r300 -dCompressPages=false -dCompressFonts=false -dNoT3CCITT -dNOINTERPOLATE -c \'save pop\' -f /tmp/010d25d2f0ef1
          D [date] [Job 1] Started filter gs (PID 4313)
          D [date] [Job 1] Started post-processing (PID 4314)
          D [date] [Job 1] Started filter pstops (PID 4315)
          D [date] [Job 1] Inserted workaround PostScript code for Kyocera and Utax printers
          D [date] [Job 1] Page = 595x842; 12,10 to 583,832
          D [date] [Job 1] slow_collate=0, slow_duplex=0, slow_order=0
          D [date] [Job 1] Before copy_comments - %!PS-Adobe-3.0
          D [date] [Job 1] %!PS-Adobe-3.0
          D [date] [Job 1] %%BoundingBox: 0 0 595 842
          D [date] [Job 1] %%HiResBoundingBox: 0 0 595.00 842.00
          D [date] [Job 1] %%Creator: GPL Ghostscript 926 (ps2write)
          D [date] [Job 1] %%LanguageLevel: 2
          D [date] [Job 1] %%CreationDate: D:20190713080526+02\'00\'
          D [date] [Job 1] %%Pages: 1
          D [date] [Job 1] %%EndComments
          D [date] [Job 1] Before copy_prolog - %%BeginProlog
          D [date] [Job 1] Before copy_setup - %%Page: 1 1
          D [date] [Job 1] Before page loop - %%Page: 1 1
          D [date] [Job 1] Copying page 1...
          D [date] [Job 1] pagew = 571.0, pagel = 822.0
          D [date] [Job 1] bboxx = 0, bboxy = 0, bboxw = 595, bboxl = 842
          D [date] [Job 1] PageLeft = 12.0, PageRight = 583.0
          D [date] [Job 1] PageTop = 832.0, PageBottom = 10.0
          D [date] [Job 1] PageWidth = 595.0, PageLength = 842.0
          D [date] [Job 1] PID 4313 (gs) exited with no errors.
          D [date] [Job 1] Wrote 1 pages...
          D [date] [Job 1] PID 4314 (Post-processing) exited with no errors.
          D [date] [Job 1] PID 4315 (pstops) exited with no errors.
          D [date] [Job 1] PID 4306 (/usr/lib/cups/filter/pdftops) exited with no errors.
          D [date] [Job 1] PID 4307 (/usr/lib/cups/filter/kyofilter_F) crashed on signal 11.
          D [date] [Job 1] Hint: Try setting the LogLevel to "debug" to find out more.
          D [date] [Job 1] PID 4308 (/usr/lib/cups/backend/socket) exited with no errors.
          D [date] [Job 1] End of messages
          D [date] [Job 1] printer-state=3(idle)
          D [date] [Job 1] printer-state-message="Filter failed"
          D [date] [Job 1] printer-state-reasons=none
          Anyone could help with this problem?
          I've searched the web for some info about this, but most of errors are for different printers (mostly HP).
          Tried to update cups and cups-filters (some users were pointing that this could be the cause)
          Code:
          [COLOR=#000000][FONT=&amp]cups is already the newest version (2.1.3-4ubuntu0.9).[/FONT][/COLOR]
          [COLOR=#000000][FONT=&amp]cups-filters is already the newest version (1.8.3-2ubuntu3.5)[/FONT][/COLOR]
          • KOBA
            • Mar 2019
            • 16
            #20
            Download link for Phase6 Linux drivers (if needed).
            • tonerhead
              • Sep 2009
              • 582
              #21
              Don't know much about pure Unix, I am moderately versed with Linux and Mac however. A common theme among my customers is they install the printers on LPD ports. I have had several Mac users swear this is the only way to install a printer other than usb. In the Linux/Mac world, I have always installed using the ip/jet direct socket on port 9100. Most of time it was like night and day for speed. Just my $.02 don't know if this applies for pure Unix.
              I've proved mathematics wrong. 1 + 1 doesn't always equal 2.........
              Especially when it comes to sex
              • KOBA
                • Mar 2019
                • 16
                #22
                Thx for reply, but I've already used socket://ip:9100 never added by LPD
                • tonerhead
                  • Sep 2009
                  • 582
                  #23
                  One more thing you can try is to go into the print language default and take it off automatic and set it to Kpdl (kyo's ps3 emulation)
                  • KOBA
                    • Mar 2019
                    • 16
                    #24
                    Printers are set to KPDL emulation.
                    In CUPS there is no place to choose emulation type.
