MFP Kyocera TASKalfa 3252ci (duplex copying is impossible)
  • evseev0784
    • Mar 2019
    • 6
    [Error Code] MFP Kyocera TASKalfa 3252ci (duplex copying is impossible)
    P.S. Service manual this model could not be found
  • Kyo fan
    • Dec 2013
    • 368
    Re: MFP Kyocera TASKalfa 3252ci (duplex copying is impossible)
    Hire a Kyocera tech.
      hmmmm with all the information ( or lack there of... should be a problem to diganose!
      You're not a tech are you?
      • evseev0784
        • Mar 2019
        • 6
        Specialists from Kyocera Companies do not go to repair to buyers. It is necessary to independently deliver the device to the service center. when considering the dimensions of the apparatus, it is quite difficult to do.
        • evseev0784
          • Mar 2019
          • 6
          I am a technician, But I am not a technician of Kiocera companies. I have not yet been on the diagnosis of this device. Just wanted to collect more information (maybe someone had experience with this problem). When I find out the reason. I will write.
          • evseev0784
            • Mar 2019
            • 6
              • 23010
              You're on the right track. You do need to start making observations, and a lot of those do not require a service manual. Like the jam code, paper tray, media type, etc. Clearly we are not on-site to make those observations for you, nor do I care to. Get started. Make observations. =^..^=
              • evseev0784
                • Mar 2019
                • 6
                Good news. The solution to the problem is extremely simple.
                For some unknown reason, one of the scanning elements of LIDE (sorry for the possible error in writing, I do not know how to translate correctly into English), those located on the ADF itself did not work.
                Solution: through the service menu I used the code 906, after this action the function of two-sided copying was available. Now, the problem did not happen again. all working.
                • JR2ALTA
                  • Feb 2010
                  • 2033
                  I am guessing you had a C3210 Code. If it only happens a couple times a year a 906 may be your best solution. If it happens more frequently and the customer is getting upset you will need to replace parts. See this post.
                  http://www.copytechnet.com/forums/ky...ht=#post599931
                  • evseev0784
                    • Mar 2019
                    • 6
                    I also thought in case of frequent repetitions of theproblem. replace parts.
                    Thanks for the link, it was extremely helpful.
