Need help with a CS-C3232 with a 6030 error. I replaced the fuser with a brand new fuser and it still comes up with the same error.
CS-C3232 with 6030 error
It was 163. That worked. Now the error went away and it makes a copy, but it gets jammed right at the exit area as it is leavign the fuser. It crumbles up like an acordian.Comment
May want to take a look at the actuator for the exit gate ass'y. Have seen these get brittle and crack causing the gate not to function properly. Kyocera calls it an "arm link". Part Number = 2C921180. Good luck..Comment
