KM-2050 misfeed problem
  • Samehwahid
    • Feb 2019
    • 22
    [Jamming] KM-2050 misfeed problem
  • drazen7777
    • Sep 2010
    • 40
    Re: KM-2050 misfeed problem
    Hy, check the spring on left side on registration actuator. (number 18 on picture)
    Poslano sa mog SM-N960F koristeći Tapatalk
    Technician -- a person who fixes the mistakes made by engineers.
    • Samehwahid
      • Feb 2019
      • 22
      Thank you for helping. That part is lost.
      Is that part responsible for picking up papers from all trays ?! Because i have misfeed problem from all trays.
      أرسلت بواسطة iPhone بإستخدام Tapatalk
      • drazen7777
        • Sep 2010
        • 40
        That spring is pulling registration actuator so that actuator can work properly, will affect all drawers, without spring actuator sometime does not go back in position and machine call s error.
        • Samehwahid
          • Feb 2019
          • 22
          Ok. Thank u a lot. Is there any think to check before order that part? Indeed I can not find spare parts in my country and It always cost me a lot to ship the parts internationally.
          • drazen7777
            • Sep 2010
            • 40
            That spring has to be there if it isnt that your reason for jams
            • drazen7777
              • Sep 2010
              • 40
              You can alco remove drawer and check inside of machine, many times i found lost spring there
                • 23010
                When testing switches in U031 you are not testing the switch through the panel, you are monitoring the switch output based on the boldness of the switch name. When you trip the switch the name on the screen will become bold. =^..^=
                • Samehwahid
                  • Feb 2019
                  • 22
                  ^____^
                  Thank you.
                  Indeed I am a beginner technician.
                  Now i learned how to check that switch.
                  • JR2ALTA
                    • Feb 2010
                    • 2033
                    If you have spare machines in your office find a spring. I have formed other springs to fix this issue instead of ordering.
                    • Samehwahid
                      • Feb 2019
                      • 22
                      • JR2ALTA
                        • Feb 2010
                        • 2033
                        This actuator can rely on gravity. That's why it works sometimes. The spring is critical, but if you cannot obtain one try to smooth out the ends of the actuator as much as possible and apply some oil where they rest. This should help prevent that flag from delaying or hanging up.
                        • Samehwahid
                          • Feb 2019
                          • 22
