C6400
  • quitech
    • 82
    C6400
    please how will i reset error code c6400 for kyocere fs 1116, i try to enter the maintenance mode by pressing 10871087 so that i can use 163 to reset but no respond. please friendsi need your assistant
    quitech
    • 23010
    Re: C6400
    Do you know what a zero-cross error is? =^..^=
    • quitech
      • 82
      Re: C6400
      I don't know, please teach me, no body is perfect
        • 23010
        Re: C6400
        To minimize the current draw of the heaters, the machine turns on the heaters in small pulses, only when the voltage is at zero (alternating current varies in a sign wave from +120v to -120v 60 times each second). If that frequency is irregular, the machine cannot accurately predict when the next zero cross will be. The machine will draw considerably more current as a consequence.
        So it's the irregular frequency of your AC power that's the problem, not anything to do with the copier. Fix the AC voltage. =^..^=
        • darry1322
          • Oct 2010
          • 817
          Re: C6400
          Good explanation of zero cross.
          • JR2ALTA
            • Feb 2010
            • 2033
            Re: C6400
            If it's like an old 1810
            enter in maintenance mode
            - Press the stop/reset key, start key and the left copy exposure adjustment key in the order presented and hold them down.
            - Press the stop/reset key.
            - Enter the number of the maintenance item to be executed using the copy exposure adjustment keys or the zoom +/- keys.
            in your case : 163
            - Press the Start key
            Or is it's like an old 1820
            -Scroll System Menu
            - highlight service mode
            - press start & # together
            - press ok
