Kyocera taskalfa 5052ci error c7304
  • veghwa
    • Apr 2019
    • 8
    Checked this machine before
    And found out Y dv is not rotating and damaged
    Change new Y dv unit
    Its ok after sometime
    Now when printing this error pop out again
    And what i do just restart the machine
    It will be okay again.
    How to check toner supply drive unit?
    Please help
  • JR2ALTA
    • Feb 2010
    • 2033
    Re: Kyocera taskalfa 5052ci error c7304
    Did you make sure the DV unit inlet hole was open when you installed it?
    • T911
      • Jun 2007
      • 628
      update firmware
      • veghwa
        • Apr 2019
        • 8
        Yes sir its working fine totally open
        Originally posted by T911
        update firmware
        This is my last hope
        Update: what i did is i cleaned the
        Toner supply drive unit
        Found out this has 4 motors with sensors attached for each color
        Cleaned and check if there is clogged toners. All working fine
        Tried to swap yellow to cyan motor plus sensor
        Installed all back
        As of now its working fine
        I leave the client and they are no updating me for trouble.
          • 23010
          Good move swapping yellow for cyan sensors & motors. If it returns as a cyan error you'll know what to order. If it comes back as yellow you can rule out those items. =^..^=
