printing issues with kyocera machines
  • TECHKYO
    • Aug 2016
    • 15
    Hello
    I am having a customer comparing kyocera printout to HP & Canon machine, from my side kyocera printout better than both but i knew that since long time kyocera machines having problem with color quality special with blue,i changed many things on kyocera such color table and tune curve u 412,410 ,952 and i got better quality, so please any suggestion or tips to improve quality of kyocera (printout).
    thanks
  • guitar9199
    • Sep 2016
    • 1100
    Re: printing issues with kyocera machines
    First thing I would try is the adjustment settings in Maintenance mode.....
    Image adjustment
    U464 ID correction operation setting (Calib)
    U469 Color registration adjustment (Auto)
    U411 Adjusting the uneven density (Normal Mode) <40 ppm only>
    U410 Adjusting the halftone automatically
    • Santander
      • May 2009
      • 768
      First off, what model are we working with? Secondly, have you changed the color profile that the machine uses? Depending on the model we are working with you may have the option to install/change the color profile the unit uses which results in different color outputs. The standard Kyo profile works for business color, but other profiles work better if the user is printing pictures or graphics. What is the customers primary printout? Business graphics, pictures, brochures? A little more info would help,
      • djs9164
        • Mar 2018
        • 79
        U 485 and change color profile to RH. It will be a world of difference.
        Sent from my XT1635-01 using Tapatalk
          • 30294
          Color matching is very hard every machine will be a little different. Kyocera Color has ALWAYS been poor compared to Konica, Canon.
          IE banding, Streaks, Fill and gradation first to last copy same run
          the only time Kyocera color was good was when they had machines made by Konica.
          • dalewb74
            • Feb 2018
            • 1157
            have you updated the firmware? have you updated the kyocera print driver to the latest? did i miss something somewhere? which kyocera are we talking about? are we comparing an older kyocera to a new hp? canon?
            • bush_tech
              • Jul 2018
              • 51
              the latest iteration of Kyocera machines finally have decent colour, the scanner still seems pretty average though
              • sparkycivic
                • Apr 2017
                • 348
                When my customers get this picky, I get best results from just showing them how to adjust the driver on their computer to alter the colors and balance, and how to save/load that final product. They usually have a handy reference (letterhead, company logo color proof, etc) with which to compare. the 52/53 series are definitely generating less calls for color q
                • JVergin
                  Service Tech / IT Rep
                  • 216
                  Depending on the model, if it has U485,
                  RH Color Profile seems better for Blues
                  CA Color Profile seems better for Purples
                  Default Color Profile seems better for Greens.
                  You can set 2 color profiles. one will be the default, and the second color profile can be accessed when printing by going to printing preferences --> Imaging --> Color Reproduction --> Custom table. There's also other built in color profiles they can play with in this drop down menu.
                  Colors will differ from model to model, brand to brand, Application to application, emulation to emulation, and even monitor to monitor. It's never going to be perfect. There's way too many variables to expect the color be exactly what they see on the screen. Changing the color profiles and educating them on the color reproduction drop down menu usually suffices.
                  • Tonerkiller
                    • Oct 2012
                    • 668
                    Kyocera is "office color" when sold and used as such, they work great.
