taskalfa 3500 scaner
  • Gab
    • Aug 2015
    • 671
    I want to setup scaner for this machine.
    I ceated a shared folter at c: and named it scaner
    Also Ip address in network is auto.
    At internet explorer wrote copiers ip address and got in the program . Wrote password, address book, contuc . Wrote user , host etc but when i checked error appeared. What i did wrong?
  • dalewb74
    • Feb 2018
    • 1157
    Re: taskalfa 3500 scaner
    what ERROR did you get? would be a bit helpful.
      • 30300
      • Santander
        • May 2009
        • 768
        First, what version of windows are we dealing with, Win10, Win7? Makes a difference. When you created the folder scaner, did you use advanced sharing or just basic sharing? Did you check the security tab on the folder you created and made sure the username you are using has full access? Is the username you are using part of a domain? Have you let file and printer sharing via SMB through the Windows Firewall? Are you using port 445? As mentioned in another post what is the error code on the display? [Error codes do not get written to the printed error report]. As you can see I have more questions than answers based on the limited info provided.
        • BabblingXombie
          • Jun 2015
          • 32
          I agree with Santander. What version of windows? Windows 10 hates smb.
          And maybe there is a 3rd party antivirus firewall...
          Info Please.
          I've setup thousands of these machines. there is always some new windows problems.
