taskalfa 3500i scaner
  • Gab
    • Aug 2015
    • 671
    I tried to set up scaner for this machine. I did it for win 7 but fo win 10 i could't although i did the same arrangements.
    Can anybody tell me where the problem is?
    Also if there is a mulfunction of hard disk. Can machine work without hard disk. ? At this case whice abilities are inaccesible ?
    • 30303
    Re: taskalfa 3500i scaner
    • Santander
      • May 2009
      • 768
      First off, the machine will not operate if it has a hard disk malfunction. Secondly, when you setup the Win10 computer and try to scan, when it fails what is the error code? The error code is only shown on the display and is not recorded on the error report. Knowing what that error code is would go a long way in diagnosing the problem.
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1888
        Search on here. Windows 10 doesn't support SMB v1 scanning.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
