Multiple document fax job
  • Rlcdrew
    • Dec 2018
    • 21
    [Misc] Multiple document fax job
    Re: Multiple document fax job
    a lil more info needed:
    WHAT MODEL?
    what are the fax settings?
    are they loading the ADF before trying to send job?
    • Rlcdrew
      • Dec 2018
      • 21
        • 23010
        I seem to recall a feature where you can set a time each day when the faxes will go out. The faxes get loaded to a specific folder throughout the day, then at a preset time it sends them all. This sounds like the best feature for your situation. =^..^=
        • Rlcdrew
          • Dec 2018
          • 21
          • Luther
            • May 2006
            • 682
            Have you looked into kyoceras accusender fax application?
              • 30434
              They could use a pdf merge program to combine before faxing. How many documents are they faxing?
              Next question is why are they NOT emailing them?
              Another option could be a shared folder like gdrive and share the folder via email.
              We had a pool company with 150 stores and would broadcast fax to all of them, service call was can't receive faxes? Yep about 1.5 hours to sent faxes out. Solution was buy another fax one send one receive.
              • Rlcdrew
                • Dec 2018
                • 21
                Well we have the custom box set up for them to share on the copier and they also have their network share folders as well. Me personally, I’ve always asked why not just email them, especially with the volume of documents they distribute. On average they send maybe 3 - 5 documents per customer. I’ve always figured the size of documents would’ve been too large for fax. Plus with new and secure features such as Docusign, I figured more would move away from faxes unless they are medical, law offices or government offices. But we still do have a fair number of clients than insist on using fax instead.
                Oh and yes for now they are using the copier’s merge function to send multiple documents, they just want it to be simpler.
                  • 23010
                  Same situation: It was a large flower distribution center associated with just under 100 branches (the only reason I remember was it was the only machine I've ever had that filled every one-touch). They would broadcast 25 pages to all 100 locations (conveniently numbered 1 to 100), and yes it did take a while. They could not receive anything during one of these broadcasts, since the machine automatically dials the next destination the moment it finishes the previous.
                  Faxes just aren't very suitable for some tasks. =^..^=
                  • NeoMatrix
                    Senior Tech.
                    • 3513
                    Duplicate RX/TX fax boards.
                    Yes some other model MFD's would allow duplicate fax boards in the same machine.
                    It would send and receive faxes at the same time.
                    Two separate physical phone lines are required though.
                    • Rlcdrew
                      • Dec 2018
                      • 21
                      • craigster
                        • Apr 2016
                        • 201
                        How about using the Lan fax driver? just a thought
                        • Rlcdrew
                          • Dec 2018
                          • 21
                          • NeoMatrix
                            Senior Tech.
                            • 3513
                            What about the old style Canon fax polling, were head office would poll all of its branch/sub companies fax machines late at night.
                            I'm not sure if polling is still a function, or if its available in other fax machines.
                            The corporate polling function would require scanning the TX document into memory first before going home at night.
                            Once the document is scanned in, all the branch/sub companies faxs could ring the head office during lunch break or late at night to RX their fax doc.
                            Both TX and RX machines must be set to Fax-Polling/Fax-on-Demand to work.
