kyocera mita 5050
  • T911
    • Jun 2007
    • 628
    kyocera mita 5050
    pf 750 lct giving me trouble with noise and jamming. feeding from the left side of the deck this lct works fine. only when transporting the sheets from the right side of the deck to the left it will make the noise (like drive belts rubbing together or like a vibration) . Unfortunately there is no room to see from the front or rear of this lct to see anything with a flashlight. The mods for when you have a lct on a 5050 have been done. the new door and the pf units. Any help appreciated. Thanks t
    • 29947
    paper feed unit pull outs left side,
    check the mounts for the paperfeed tires ie metal bracket that holds them in place plastic ta.bs brake off.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1870
      Yep, it's the metal ground that runs through the plate. Either JB Weld it. or zip tie it.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • T911
        • Jun 2007
        • 628
        thanks guys it was a one way in there.
        • B0265
          • Jan 2007
          • 718
          There's a tech bulletin about this problem. I have the parts on backorder from KM Europe for 2 months :-(
          • T911
            • Jun 2007
            • 628
            b0265 thanks much for the bulletin. i checked all parts referenced in that bulletin and all are ok. this one makes noise transporting from the right to the left side of the deck. when feeding from the left only it's ok. i have to spend more time on this and drop all the panels off to see what the hell it is. ideas, suggestions appreciated.
            • vikingmita
              • Nov 2008
              • 163
              longshot: when assembling someone lifted the pf out of the box from the bars who have the whole feedunit slit into them. you know, the bars clearly stated on the attached sheet on top of the pf NOT to use to lift it out of the box when unpacking...
              if bendt like a banana, lift machine off and straighten bars out. this is really old news, but just in case.
              • LNorris
                • Sep 2008
                • 645
                from my view, every one of these feeders have had the clip broken off that causes the same thing. its easy to miss on a casual inspection. we ordered the new parts and already have them in. looks like i have some work to do
                • B0265
                  • Jan 2007
                  • 718
                  So I received the repair kit "ASY-X", and it's a cable tie and and film but no installation instruction.
                  Have anyone installed this?
                  • T911
                    • Jun 2007
                    • 628
                    solution::::: found the f-cker. i focused to much on the right side of the deck but it was the left clutch coming up off the frame when trying to refeed from the left. self tapped a screw in so it won't come up off the frame. thanks for the help guys.
                    • B0265
                      • Jan 2007
                      • 718
                      Did you receive any installation instructions for the film and cable tie?
                      • LNorris
                        • Sep 2008
                        • 645
                        no, there were no film or cable ties with any of the ones we ordered. just the "hold down" plastic is better built than the original.
                        • B0265
                          • Jan 2007
                          • 718
                          What part no did you order?
