kyocera KM-2550
  • archiectn
    • May 2025
    kyocera KM-2550
    Good day!I have problem with Kyocera KM-2550.The first time I've checked the machine it only need to be replace with new toner cartridge.Eventually, the new toner was put inside.After I left the place the machine indicates checked toner container,& the customer call me back.I checked again I removed & returned the toner cartridge inside.I already replaced the waste toner tank also with new one.I made several copies & its good,after one day the problem comes back.I need help.
    Thank you
    • 22930
    Was it an OEM toner cartridge that you installed? Most Kyocera products have an RFID sensor that identifies an OEM cartridge.
    Have you checked the associated drive for the toner cartridge and the developing unit? =^..^=
    • banginbishop
      grumpy old git
      • Oct 2007
      • 894
      If this is the "reseat toner" message its down to the toner cartridge being non oem and i had to adjust the blue collar that holds the toner in place or as black cat says check the toner drive.
      Incontinentia Buttocks
      • termacadon
        IT goofball
        • 66
        Im going out on a limb here, but,make sure its the correct toner cartridge and not for a 1650 or 2050.
        • 10871087
          • Jan 2005
          • 1143
          The KM-2550 toner DOES NOT use RFID
          Your toner might not be fully inserted or you might have a broken auger inside your toner container.
          • aragul
            • Dec 2007
            • 128
            There's a switch behind the toner container. I've never had one of these fail, but it looks similar to the Falcon toner container detection.
            It's part number 2C927140, item 38 on Figure 2. Also on the parts list page, the unlabeled part to the top left of the switch is the "key" that prevents 1650/2050 toner from going into a 2550.
            • tech
              We had the same problem "check toner cartridge" we were told to take the blue knob that now comes with all of the new toners and turn the toner gears until these gears can turn extremely smooth. The toner motor is way too weak to turn the slightly bound up toner cart. The problem has not come back.
              • ExOceMan
                • Sep 2009
                • 63
                I have seen these cartridges look very similar but have different drive couplings at the rear. So the toner would not come out but the cartridge would still fit.
                • dickierock
                  • 252
                  Had this before, simply wedge a folded piece of paper between the toner cart and the blue lever to push the cart fully into the machine and then the sensor is fully activated,hope this helps..
