kissy
  • kissy
    kissy
    • Mar 2008
    • 7
    kissy
    I am facing problem in the brand new KM-6030 copier as it gives error code C 4110. I try to reset it by sim 906 but of no use. Copier had made just 3500 copies and it is just one month before installed.Any help appriciated.
    • 23007
    Does your machine, perchance, have firmware Engine version 360, Main version 185? Check the firmware versions in simulation U019.
    The latest firmware release has bugs related to the laser. If so downgrade the firmware to Engine version 352, Main version 184.
    The code that I got was C4200, but it could account for your C4110.
    • Hose1cook
      Defective Technician
      • Jun 2008
      • 80
      I had one a few weeks ago with the same problem. Brand new machine out of the box, connector YC8 was loose, worth a look.
      • texchar555
        Senior Production Tech
        • Mar 2007
        • 142
        Try checking the door interlocks, make sure they are not 'bouncing' open & closed. Also, I have had a couple 8030's with the Laser harnes wire ties on too tight, they were cutting into harness.
