Fleet Services - Turn off Remote Services
  • kuby
    • Oct 2007
    • 1388
    How so how can you go in and turn OFF Remote Services so I can change the Access Code. It is greyed out on both the copier and the web interface.
  • progoffice
    • Nov 2008
    • 334
    Re: Fleet Services - Turn off Remote Services
    You can use U520 to turn off Remote Services and start over with new settings. If it's a printer, simply delete it from KFS and that should allow you to make changes through the Command Center again.
    • kuby
      • Oct 2007
      • 1388
      Went into U520 and tired to access the Registration and Access Code but it is greyed out.
      • progoffice
        • Nov 2008
        • 334
        That is correct. Once you're in U520, You have to go to "On/Off Config" and turn it off. This will reset the KFS settings back to default.
        • kuby
          • Oct 2007
          • 1388
          Thanks, I think I got it.
          • tmaged
            Owner/Service Manager
            • Oct 2008
            • 1863
            You have to turn it off in 520 & be sure to go into KFS & delete the machine. You can't register a machine that is already in the database. It must be removed first.
            Hope that helps !
            -Tony
            www.dtios.com
            Become a fan on Facebook
