Waste toner 2 series.
  • djs9164
    • Mar 2018
    • 79
    [CQ] Waste toner 2 series.
    Anyone have a fix for the dreaded grinding sound from a waste toner backed up? I'm getting to hate when I recieved a noise call on this series.
    Sent from my XT1635-01 using Tapatalk
  • copiertec
    • Jan 2016
    • 2211
    Re: Waste toner 2 series.
    Color or Mono?
    • djs9164
      • Mar 2018
      • 79
      Both seem to have the issue.
      • craigster
        • Apr 2016
        • 201
        just replace them with latest one and warranty it. Latest one seem to work much better.
        • kevin.coleman1
          • Mar 2017
          • 13
          • Geo
            • 662
            Two major VERY important things to check when replacing the waste assy.
            1) Make sure that the waste toner bottle is rotating , if it's not this will cause the waste assy to seize.
            2) Check the waste toner auger on the transfer belt and make sure it's not seized and the drive dive isn't rounded off.
            If the waste bottle isn't rotating your problem will happen again depending on usage , from a couple of days to weeks.
            Did I mention that it's very important to check these to assemblies ?
            Have fun...
            • djs9164
              • Mar 2018
              • 79
              Put th new unit in. Over 2 hrs labor. Did I mention I hate Kyocera.
              • sparkycivic
                • Apr 2017
                • 348
                my quick check for the waste container drive/mis-shapen housing: grab the bottle and twist - if it moves by hand, the housing is borked. if it's tight, pull the main drive pack and go through all the waste passages.
