FS 4200 dead USB port
  • dany_07
    • Sep 2017
    • 3
    [Electrical] FS 4200 dead USB port
    Hello frinds! Has anyone managed to fix a USB PWB with dead usb on these printers? I have multiple Kyocera FS 4200 USB PWB that don't comunicate with the pc. The usb port is simply dead. The printers runs perfectly, except this. Thank you for your answers!
  • GeneOR95
    • Feb 2018
    • 161
    Re: FS 4200 dead USB port
    The first thing I would check is in Command Center;
    Basic > Security > Device Security > Interface Block
    This page allows you to restrict access from each interface.
    Network, USB Device, USB Host, Parallel I/F, Optional I/F
    Specifies whether or not to restrict access from each of the interfaces above.
    Access from the interfaces that are set to Block is restricted
    If USB is blocked, unblock it and check.
    • dany_07
      • Sep 2017
      • 3
      Checked all items in that menu, all are set to "unblock". I think that is an electrical issue. A condenser or another piece from the usb PWB may be broken.
      • Scott
        • 196
        Not to sound stupid, but please tell me your talking about the USB port in the back and not the front.....just asking.
        • JR2ALTA
          • Feb 2010
          • 2033
          Are you computer savvy? Have you checked Windows Device Manager for a missing driver?
          When I setup printers out of the box the USB instructions are very particular about when to run the CD and when to connect the cable because you can get in this situation.
          • dany_07
            • Sep 2017
            • 3
            Yes, the USB port in the back of the printer. The one in the front is for other purposes. I know. The same printer works fine on USB, conects to PC and prints ok if I change the main PWB. The whole asembly with the USB port.
