Kyocera 8001
  • lvcopiers
    • Sep 2015
    • 2
    Kyocera 8001
    Kyocera 8001, skewing exiting the copier into the finisher.
    Scott Keikoan
    Las Vegas Copiers
    702.823.9445
  • Scottb
    • Apr 2013
    • 303
    Re: Kyocera 8001
    Scott Keikoan
    Las Vegas Copiers
    702.823.9445
    if it's the paper skewing I would check the two mylars on the exit side of the bridge unit, if the image is skewed I would check the white idler rollers below the reg roller on the conveying unit.
      • 22997
      Re: Kyocera 8001
      Where is the actual skewing happening? Emergency stop the machine a few times to determine where.
      If it's in the bridge, it's pretty common for the upper white idler rollers can fall out or dump their pressure springs so the tension is uneven front-to-back. The only thing that keeps the shaft and roller installed in the upper guide is a snug keyhole slot in the upper guide which might not be very snug any more.
      This was my MacGuyver to get a few more weeks out of this machine:
      • Happy Copier
        • Mar 2019
        • 49
        Re: Kyocera 8001
        [ATTACH=CONFIG]43181[/ATTACH]
        What's the red stuff?
        Sent from my SM-G930V using Tapatalk
          • 22997
          Re: Kyocera 8001
          Grease. I am a big fan of IBM23 but that's getting pretty hard to find. I read on a typewriter forum that Mobilegrease28 is an excellent substitute for the clay based IBM23. Technically it's considered an aircraft quality lubricant. The only major difference that I can see is that IBM23 is tan colored and Mobilegrease28 is bright red colored. =^..^=
