Can you put a TA 4550ci in a TA 3550 machine ?
  • Doug James
    • Jan 2012
    • 935
    [CQ] Can you put a TA 4550ci in a TA 3550 machine ?
    I have several used 4550 ci fusers and have a 3550ci in the field which is giving me fusing problems.... (Toner not fusing on lower half.) To troubleshoot, I am hoping to try to use a 4550ci fuser. Anyone ever tried this ? Thanks so much !!!!
  • Happy Copier
    • Mar 2019
    • 49
    Re: Can you put a TA 4550ci in a TA 3550 machine ?
    I'm not sure about those models, but the 3551ci and 4551ci fusers aren't compatible
    Sent from my SM-G930V using Tapatalk
    • ntbann
      • Jan 2012
      • 628
      According to bulletin #1 they are different. The 4550 5550 are the same.
      • JPazy
        • Jul 2019
        • 30
        The 4550ci/4551ci fuser units FK-8500 are not compatible with the 3550ci/3551ci's fuser units FK-8300. If i remember correctly, the screw hole alignment and connections are different, making it impossible to swap the two items.
        • Doug James
          • Jan 2012
          • 935
          Thanks so much !!! Huge Help !!!
