Kyocera KM-2560
  • Hadi
    • Jan 2019
    • 15
    Kyocera KM-2560
    Hey. I have a problem with Kyocera KM-2560 . I'm not a kyocera technician, that's why I have a question for you. When printing, leaves a black band. SM says that is problem with drum unit. What to change? Drum cleaning blade? Electrode? I change cleaning blade but still same problem. Fuser is clean. Where to find the reason?
    Re: Kyocera KM-2560
    sounds like you are out of your comfort zone.. hire a tech
      • 23008
      Re: Kyocera KM-2560
      Your line is not very apparent in the photo. Is it in the feed or crossfeed direction? Does your line pass through the voids or not? I kind of doubt that you changed the drum cleaning blade since those drums come as complete units, not separate parts. Do you have a better illustration? =^..^=
      • JR2ALTA
        • Feb 2010
        • 2033
        Re: Kyocera KM-2560
        I see it by the meter counts.
        Drum, dev or fuser. Be a tech and figure out it.
