C2500 error
  • justfix
    • May 2008
    • 19
    Re: C2500 error
    Originally posted by what_moustache
    And so far so good on the repair. Well over 1000 pages out of the machine since the fix & no codes so far.
    So you got it fixed by replacing the right door unit, great job!
    • justfix
      • May 2008
      • 19
      Re: C2500 error
      So I went the cheap way. I disconnected those right door clutches (Thanks to KYO-OEM), two of the three were totally rusty. I thoroughly cleaned them with compressed air and an electronics cleaning agent. I put them back and the device now works flawlessly. If the fault comes back I know where to look and no longer have to hit the old head on the wall
      • dacam20590
        • May 2019
        • 30
        • justfix
          • May 2008
          • 19
          #19
          Re: C2500 error
          dacam20590,
          you obviously quoted my text, read it carefully the answer is in it, at least in my case. See also the KYO_OEM instructions with pictures above.
          • dacam20590
            • May 2019
            • 30
            #20
            Re: C2500 error
            i'm replace duplex and the fault code is gone.i do not which part is fault duplex(clutch ?)
