C2500 error
  • brancas
    • Jul 2009
    • 80
    C2500 error
    Good day all. Customer's TA 5052CI can print from cassette 1 and 2 intermittently but paper z folds and jams in fuser unit and errors out. From cassette 3 and 4 jams in fuser unit and also errors out. Replaced feed drive unit, fuser motor,fuser unit, exit unit, feed image pwb and engine board. Updated to latest firmware as well. Problem still exists. Any ideas?
    • 23009
    Re: C2500 error
    I would have put my money on the feed drive PWB + firmware. =^..^=
    • brancas
      • Jul 2009
      • 80
      Re: C2500 error
      Feed PWB was changed along with firmware.
      • Geo
        • 662
        Re: C2500 error
        When the Z fold happens , does the leading edge of the paper make it out of the fuser and by how much? Or does it jam at the entrance and never makes it through the fuser nip?
        • Santander
          • May 2009
          • 768
          Re: C2500 error
          Have you pulled an event report in service mode? Are there any jam codes displayed either on the screen or in the event report or do you just get the C2500? With everything you have replaced the C2500 code should have been resolved. There are several reflective optical sensors in the conveying path that can get coated with paper dust providing false indications to the machine. Don't forget to clean the areas opposite the sensors as the paper dust accumulats there as well and can provide enough reflection to make the machine think there is paper there.
          • copymandan
            • 3
            Re: C2500 error
            i dont know if you got this one yet but i had a c2500 error that ended up being a broken duplex transport shaft the one hardest to get to behind transfer assy. it was a freak thing but thought i would mention it
            • veghwa
              • Apr 2019
              • 8
              Re: C2500 error
              Any one solved this issue?
              I have same problem now with utax 4006ci
              Run simulation 21 and 2 to reset.
              Replaced feed drive unit and fuser unit
              Planning to replace fuser drive unit and engine board.
              But as what ts said he already replaced and no luck
              Please halp
              • justfix
                • May 2008
                • 19
                Re: C2500 error
                Good day gents! Old thread, I know, but the error is still alive, just hit it at last week. Did you guys ever solved the issue and what was the culprit?
                Thank you for your help in advance!
                • KYO_OEM
                  • Aug 2011
                  • 721
                  Re: C2500 error
                  i don`t know the fix from the other technicians, but i my case it was a drive problem inside from conveying unit.
                  • justfix
                    • May 2008
                    • 19
                    Re: C2500 error
                    Thanks for chiming in KYO_OEM, I greatly appreciate.
                    You mean right cover conveying unit?
                    Like brancas i have exactly same problem with one side prints, not even test the duplex.
                    • KYO_OEM
                      • Aug 2011
                      • 721
                      Re: C2500 error
                      Have had 1 case with 1 broken clutch in parts right cover assy.
                      Check all 3 clutches and drive belts
                      fig.15, paper conveying section 2:
                      • justfix
                        • May 2008
                        • 19
                        Re: C2500 error
                        Thanks for the tips KYO. To be an old fart, I am currently really overworked but I'll try to dig some time
                        in the next few days to get to visit the customer before they get totally mad. I let you know how this ends, sooner or later.
                        • what_moustache
                          • Jan 2015
                          • 15
                          • justfix
                            • May 2008
                            • 19
                            Re: C2500 error
                            Originally posted by what_moustache
                            (by replacing the feed drive unit without fixing it)
                            In my case too it was waste of time and money, I even replace the reg.clutch same time, was a little bit rusty.
                            Replacing whole right door unit, easy but expensive, especially if the fault is not there...
                            • what_moustache
                              • Jan 2015
                              • 15
                              Re: C2500 error
