Paper Path Test
  • wertyxhts
    • Jul 2018
    • 19
    Paper Path Test
    Hello,
    Just switching over from HPs to Kyoceras. Is there a mode like paper path test on Kyoceras to test jamming? Something similar to HPs, where you can run multiple test prints. For now, I've been just printing font lists and status pages.
    Particularly these models: Kyocera P3055 / Kyocera M3550 / Kyocera M3655 / Kyocera P6035 / Kyocera M6635
  • Tonerkiller
    • Oct 2012
    • 668
    Re: Paper Path Test
    I just put a pdf on a thumb drive. Like a firmware pdf 20 or 30 pages.
    • Scottb
      • Apr 2013
      • 303
      Re: Paper Path Test
      U030 Checking the operation of the motors
      U031 Checking switches and sensors for paper conveying
      U203 Checking DP operation
      • JR2ALTA
        • Feb 2010
        • 2030
        Re: Paper Path Test
        Why do you call it a "firmware pdf"? You mean like the readme that comes out with f/w or something else?
        • JR2ALTA
          • Feb 2010
          • 2030
          Re: Paper Path Test
          Those aren't on printers and wouldn't pass paper anyway.
          • Tonerkiller
            • Oct 2012
            • 668
            Re: Paper Path Test
            Yep, same, Readme is a new term. I have always called it the "firmware pdf" In other words the pdf that comes with the firmware.
            • Scottb
              • Apr 2013
              • 303
              Re: Paper Path Test
              [QUOTE=JR2ALTA;797240]Those aren't on printers and wouldn't pass paper anyway.[/QUO
              OOPS sorry I was in a hurry to deliver a machine, and yes you are correct the they are not on printers. The U203 is on the M models that he listed and it will pass paper....
                • 22999
                Re: Paper Path Test
                Something like this?:
