sleep or power saving modes
+ More Options
Posts
  • oldtech1
    • Mar 2008
    • 35
    I have a few Kyocera's 3011 and 5526 that will not wake up after a day in the low power or sleep modes. Customers have to unplug the machine to get them to power on. I have seen a lot of F60A codes on the machines. Where do you turn off power saving on the nic card or fax?
  • ntbann
    • Jan 2012
    • 628
    Re: sleep or power saving modes
    Have you updated the firmware?
    • oldtech1
      • Mar 2008
      • 35
      firmware has been updated to the latest. I also had a 5521 throw a F000 after we updated. had to order a main board for that one. the customer was not in office and when he came back the next day the F000 was on display and could not be reset.
      • JPazy
        • Jul 2019
        • 30
        Might want to try changing the Sleep Level from 'energy saver' to 'quick recovery', we had success with a customer with the same problem, but they were using Paper Cut.
        • patrickjlc
          • Feb 2015
          • 225
          And you can also set the energy saver settings for the networking and fax, machine goes to sleep but those two boards remain awake.
          Sent from my SM-G930V using Tapatalk
          • KYO_OEM
            • Aug 2011
            • 719
            Switch off U520
            F60A means KFS communication lost.
            Mostly by night, the systems are loosing the connection to KFS servers.
