Ecosys M6635cidn Twain scanning
  • iscott
    • Mar 2010
    • 344
    Set up a new M6635 at a location that was using a M6535 (Which was twain scanning fine) The scanner connects fine it shows as a scanner option in all the scan programs. When you press scan the scanner option interface never comes up. No scan image or any thing. This even happens when using the Kyocera Quick Scan program. This also happens when you connect directly to the copier via network port. FYI Scan to email works fine.
    So for Kyocera tech support has not been able to resolve this issue.
    Any help from the outside world would be appreciated.
    • 30462
    Re: Ecosys M6635cidn Twain scanning
    Did you download the twain and setup scanner? Kyocera you must setup the scanner and enter the correct machine model once you install the software
    • iscott
      • Mar 2010
      • 344
      Yes Kyocera tech support remoted in and loaded everything again same result.
        • 30462
        Reboot pc and test if still not working
        Uninstall all the kyocera twain drivers and reboot
        than reinstall the latest driver and test.
        • iscott
          • Mar 2010
          • 344
          Deleted and reloaded multiple times.
            • 30462
            Can you try it on another PC or your laptop and test
