TA-4501i Cf26f error
  • copiertec
    • Jan 2016
    • 2172
    We have a TA-4501i that will get a Cf26f error, using the latest KX driver (7.4.15), latest firmware v7.02, but it happens with the night crew so it is hard to diagnose during the day as the day crew has no issues.The morning crew comes in and we get the call that they have to restart the copier to clear the error. At first it was getting a C0640 error along with the Cf26f, so we replaced the HDD and no longer have the C0640 error.
    I am thinking it is something they are printing and the copier is not understanding the language of what they are trying to print. Computer OS is Windows 7, not sure of the server OS. Any other ideas?
    • 27449
    Re: TA-4501i Cf26f error
    What is the PDL set for? Should pcl5 not pclxl. Also see if you can find the workstation and the doc that was printing
    If PDL was set for pcl5 change to kdpl
    • copiertec
      • Jan 2016
      • 2172
      Thank you, bsm2, I will check the PDL settings when I go there today, change them around and run some test prints from the workstation.
        • 22702
        Clearly its something external to the MFP if first shift remains unaffected. Maybe you are getting some corrupt print data (like a wrong driver), or non-print data coming to that IP address. Do your endusers use web based applications or print a lot of web pages? =^..^=
        • Scott
          • 185
          We get those codes when people are trying to print off the internet, recipes seem to be the worst
          • copiertec
            • Jan 2016
            • 2172
            Thank you, blackcat. They are printing from an application I suspect from a server, as they have to log on to it, it is called Veg (I think), they are a produce distributor and print out several hundred orders a night. I stopped in today to talk to the day shift and the one person had said they sometimes have that issue but restart the copier and everything is fine.
            I changed the driver to pcl 5e as bsm 2 had suggested, printed some orders and no issues, but, we will see what tonight turns out.
            I find changing the new driver to pcl 5e format more difficult as there is not a save button anymore, now there is a save profile as, instead, it took me about three try's to get it to save the pcl 5e as the default.
            • copiertec
              • Jan 2016
              • 2172
              Thank you, I have had the same issue, Scott, and that was my first question... but they are printing from a server based program.
              • copiertec
                • Jan 2016
                • 2172
                Thank you, it was set to pcl xl (default) settings, I changed to pcl 5e and hope for the best. I personally feel that there system ( everything included pc's, network, server (possibly, just a guess) and programs are old), needs some updating, they are still running Windows 7 Pc's and seems like an antiquated server based program. If there are still issues I will at least try kdpl before I throw in the towel.
                Might I add, they have had this copier for three years with no printing issues, until the past month, which leads me to believe their technology connected to the copier may need some updating!
                • copiertec
                  • Jan 2016
                  • 2172
                  Thanks for all the input and help. I tried all the driver combos, still was having the issue. I think I may have boiled it down to a bad (crushed) network wire. I went to the client first thing this morning while the machine was in an error state, cf26f, cleared the code and had the client resend the job. It started to print and stopped around the 45th page and the memory light kept blinking, but no data light, eventually the copier would code out. So, I decided to trace out the network cable and low and behold they had set a pallet full of product up against the network wire leading from the switch to copier, I had them remove the pallet(s) and replaced the wire and the copier prints with no issues.
                  Hopefully, this will resolve the issue, time will tell.
