KM 4035
  • copicatt
    • Nov 2008
    • 366
    #16
    I will start again this morning. The white plate has no black streaks on it but there is a scratch or cut across it, almost like a knife cut, but it's not in the "exact" area, but close. I will swap that plate from another DP.
    • copicatt
      • Nov 2008
      • 366
      #17
      swapping the feeder took care of the problem. Didn't see anything on the white plate but a cut, but I guess that was enough....thanks for the input....
      • sfragis
        #18
        I had a similar problem once and it turned out to be a very thin hair stuck in the feeder, almost impossible to notice...
        • West Texas Flash
          • 10
          #19
          I had the same problem once that turned out to be an imperfection in the slit glass. I couldn't see it but I could feel it by lightly pushing a razor blade across the glass
