KM 300i copies
  • kmtech
    • Sep 2008
    • 125
    KM 300i copies
    this machine runs outta toner in the developer unit, without toner add light coming on! I have replaced Dev unit, still no luck, im starting to think Main board just wanted to get another opion.
    Thanks in advance.
    Bill
    • 23009
    Re: KM 300i copies
    Yeah, the main PWB make the most sense if toner is never being added to the developing unit and you don't get an Add Toner indication. What happens when you run U130? Does it fill the developing unit? Can you run the toner motor in U030? =^..^=
    • eddie110171
      • May 2012
      • 133
      Re: KM 300i copies
      I would check the connector on the front of the DV, if that harness got pinched/damaged it would cause an issue like that.
