Taskalfa 6052 ci with noise in right side duplex area
  • chester
    • Jun 2016
    • 37
    I have a taskalfa 6052ci with a constant noise when selecting duplex mode, in single mode it is fine.
    The noise happens in the right hand door, I have ruled out the exit unit which I have checked and applied all the modifications to.
    Just wondering has anyone had issues with clutch's making a noise in the right side unit?
    Before I strip the unit down I would be grateful if any suggestions can be made.
  • KYO_OEM
    • Aug 2011
    • 725
    Re: Taskalfa 6052 ci with noise in right side duplex area
    Havn`t had noise from clutches right door, but have had several rusted clutches in paper feed/ paper conveying sections.
    Maybe running U032 with "motor" on and checking clutches step by step can be helpfull.
    • Tonerkiller
      • Oct 2012
      • 669
      I have had a couple. Taking the drive on the door apart and cleaning the clutches will only last for a couple of days. I have been just replacing the entire door.
      • callservice
        • Sep 2011
        • 26
        check the clutches. if dirty replaced it. check the rollers and bushings .Lubricate the bushings.
