Copystar 3511I /DF7120/ ERROR C8210
  • cucuklotz
    • Mar 2007
    • 611
    Hi
    The stapler on the DF 7120 when it leaves the home position travels to back of machine and overrides the stop and periodically get stuck,
    I cleaned the tracking but it didnt help.Has anyone had this problem before.The stapler cable seems to be in correctly and not loose.
    The result is an error C8210
    I appreciate any help and THANK YOU in advance
    Andy
  • KYO_OEM
    • Aug 2011
    • 711
    Re: Copystar 3511I /DF7120/ ERROR C8210
    Check guide stapler/ 303NB38180
    Sometimes stapler is out of position because of missing/ broken guide
    • copytech_32716
      • Nov 2022
      • 17
      Having the same issue. Seems like the stapler is driving past the sensor and then getting hung up.
      Tried swapping almost everything already. Anyone else seen this?
      This is a brand new unit out of the box. Mine is on a DF-7110 though.
