Kyocera KM-2530 How to adjust printing exposure
  • ToddS
    • Sep 2019
    • 8
    [Misc] Kyocera KM-2530 How to adjust printing exposure
    Hi,
    The printer defaults, accessed through the "Management Code Menu" (the * button), for "Print Density" is set to the maximum darkness (#05). Print jobs are too light. I believe there is another method to set darkness, please help if you know what that is. The copier is equipped with the optional Printer/Scanner kit. The regular copy function has a proper range of light to dark, it's just the printer section that needs to be darker.
    Thanks!
    Todd
    • 30444
    Re: Kyocera KM-2530 How to adjust printing exposure
    Check under printer menu it's very odd to ever have to adjust print side
    are you using the correct print driver? should be kx driver
      • 23010
      I think it's in the PreScribe commands ...
      ... yes, try this:
      Send the following PreScribe command: !R! FRPO D4,4;EXIT; to set print density to 4. (range 0 light to 5 dark)
      • ToddS
        • Sep 2019
        • 8
        ... yes, try this:
        Blackcat4866, thanks! From other research I have been doing, that appears to be the correct command, the problem is I'm having trouble getting the copier to accept the command.
        The copier is connected to the office network with a CAT5 cable, a PC also connected to the network, is being used to communicate with the copier. From the command prompt, I am able to ftp the IP address of the copier and correctly supply the password resulting in "230 User Logged in."
        At this point I want to print a status page before I change anything so I send the command: " !R! STAT 1; EXIT; "
        The computer responds with " 'R!' is not recognized as an internal or external command, operable program or batch file ".
        Notice the computer response does not include the first " ! " in " !R! ".
        BTW: I do know how to obtain the status report directly from the copier control panel, I first just wanted to try a !R! command that would not change anything.
        Any ideas what I'm doing wrong? Anybody?
        Thank you ahead of time for any help!
        Todd
        • ToddS
          • Sep 2019
          • 8
          Re: Kyocera PreScribe Command - How to?
          Thanks much to the guys that responded to my original question.
          It appears I need to send a PreScribe command to the copier, Kyocera KM-2530.
          I believe I have the correct command and format, but the methods I've tried to communicate with the copier have been unsuccessful.
          Can someone please provide step by step instructions, I'm screwing it up somewhere.
          Thanks!
          Todd
            • 23010
            If you model does not have a place on the webpage to place commands you'll need a utility ... either LPR Jar or IC Link. =^..^=
            • ToddS
              • Sep 2019
              • 8
              Thanks blackcat4866, you were right, I needed a utility, I'm now using "Copy To Printer" which is simple and works well.
              I still have not solved the original problem with this Kyocera KM-2530, print density D4 is set at the darkest, 5, and print jobs are too light. The copy function has great light to dark adjustment, print does not.
              To summarize:
              Kyocera is hard wired to the LAN with a Cat 5.
              Been testing the same print job on two separate PCs also hard wired to the LAN, both print too light when sending job to Kyocera.
              Each of the two PCs have their own printer, one a laser, the other an inkjet. When same print job sent to their own printer, they have adequate darkness. The print job is a Word document table with shading in certain fields, the shading is printing too light.
              To check the range of darkness, Print Density on the Kyocera has been changed from 1 (lightest) to 5 (darkest), there is not much change, nowhere near the light to dark range using the copy function.
              Any ideas?
              Thanks,
              Todd
                • 30444
                To summarize:
                Any ideas?
                Thanks,
                Todd
                Web into copier and check printer, never had to adjust printside only. Look for something in the printer menu is off a standard setting , is eco mode set to on? eco mode should be off That would screw it up
                  • 23010
                  I don't think FalconI had EcoPrint. =^..^=
                  • ToddS
                    • Sep 2019
                    • 8
                    Thanks bsm2, good suggestion, but EcoPrint mode is off ( N6 set to 00 ).
                    blackcat4866, your hilarious, I actually laughed out loud when I read "Falcon I".
                    I have attached the Interface Dependent & Interface Independent Parameters below,
                    in case something jumps out at you.
                    Thanks!
                    Todd
                      • 30444
                      !R! FRPO INIT; EXIT;
                      Resets to parameters to original
                      Old Machine , trade in time
                      PS Kyocera'a always had eco mode in any machine that printed
                      Old machine had access to command changes from web page you can double to see if something is checked or changed
                      good luck
                      • ToddS
                        • Sep 2019
                        • 8
                        good luck
                        bsn2, thanks for the suggestion. I was afraid to do a reset as it was unknown how many parameters I would need to change back, guess what, ONLY the Print Density D4 changed from 5 (the darkest) to 3 (the middle setting). Since that didn't improve the situation I reset D4 back to 5, still just as light as before.
                        If anybody has any revelations leading to a solution, I would be happy to hear them, otherwise I feel I'm at a dead end. Trade it time? Everything else with this machine works great and the copy counter is still very low, that's a tough sell.
                        Thanks guys for your input!
                        Todd
                          • 30444
                          Todd
                          The reset should not effect anything unless it was changed.
                          Since your machine is screwed up it.
                          PS almost never ever had to do any frpo changes to equip
                          Unless some tech screwed with them or Kyocera recommend.
                          This is an old machine an I think still has old style pots you could turn with screwdriver on the hv board guessing someone tweak it.
