Kyocera M2535dn ADF will not try to pickup - dead adf
  • skibum
    Independent Service Tech
    • 231
    I have a M2535 that only will click on the electromagnetic clutch but there is zero adf main motor start up. The solution is either the Harness or the small ADF pcb that the adf harness connects to. When I swap them both out it resolves it. I need to go back to confirm, I just ran out of time to discover which it was. Did anyone else have this happen and it was the harness? They use the glass manually a lot so this makes the most sense.
    Thanks in advance for any thoughts.
  • martinar
    • Mar 2017
    • 27
    Re: Kyocera M2535dn ADF will not try to pickup - dead adf
    CONN. CORD ASSY INTERFACE
    303LJ46010
    Try that, or check continuity over the interface cable.
    • dschultz31
      • Aug 2018
      • 33
      Had this same thing on a 1135, it was the harness. I took one from a 1035. It worked. I didn't bother figuring out the harness issue, I just tossed it.
