Is a TA 3050ci compatible with SMB3?
  • qtech
    • Jul 2009
    • 41
    Just had a customer upgrade their entire system to MS Server 2019 and now their 3050ci won't scan even with the last firmware installed (no immediate error code, the scan just hangs there then gives an Error:Connect on the print out when you cancel). There is no option to revert to SMB1 on this server (so I'm told), so the bottom line is......is FTP the only way out other than upgrading the machine?
    Many thanks,
    Chris
  • Kyo fan
    • Dec 2013
    • 368
    Re: Is a TA 3050ci compatible with SMB3?
    Yup, it's either FTP or e-mail.
    • kuby
      • Oct 2007
      • 1413
      See various ways to detect, enable, and disable the Server Message Block (SMB) protocol (SMBv1, SMBv2, and SMBv3) in Windows client and server environments.
      Good article but you have to be careful about letting virus' in.
      • HenryT2
        • 962
        Check with Kyocera . They have some firmware for older copiers , and some MFP's , that will allow communication for SMB v2 and v3 . Perhaps they will have the firmware you need .
        "The Serenity Prayer" . . .
        God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
        • tmaged
          Owner/Service Manager
          • Oct 2008
          • 1900
          Henryt2 is correct. Get it from your area sales manager. It is available for this series.
          Hope that helps !
          -Tony
          www.dtios.com
          Become a fan on Facebook
