TASKalfa 7002i - add toner issue
  • kuby
    • Oct 2007
    • 1400
    We have a 7002i that is having a toner/motor issue. It was saying that the NEW toner cartridge we put in only had 6% toner in it and would keep trying to add toner. It would add toner then make about 50 copies and start the add toner thing again. We installed another new toner and it showed to have 100% toner but then after 250 copies it started the add toner thing again. We made sure it had the latest firmware and even reinstalled the full firmware but it did not help. We installed a new motor and that did not help. We are thinking maybe a sensor issue but we do not know where to start or if you have any suggestions we would appreciate it.
  • Santander
    • May 2009
    • 768
    Re: TASKalfa 7002i - add toner issue
    It appears you have a toner sensor error. You could try running sim 130 & 131, but it is most likely a bad toner sensor in the developer unit. I would start with replacing the DV unit first.
    • sweet.persona
      Engineer
      • Nov 2009
      • 414
      Replace toner sensor it's seem bad or weak or intermittent signal
      A GREAT PLACE TO WORK - A GREAT PLACE TO GROW!
      DAMENE ABDEL AZIZ
      DJELFA
      • KYO_OEM
        • Aug 2011
        • 712
        Please remember toner hopper motor/ toner hopper sensor.
        At this system you can change toner on the fly.
        Which motor you changed?
        Maybe faulty connection for toner hopper sensor.
        If always "ON" state, toner motor won`t turn.
        Check connection for toner hopper sensor on front pwb YC8/ Pin18 + YC10/ Pin 8
        • kuby
          • Oct 2007
          • 1400
          Changed the feed drive assy for the K unit. Now it adds toner but stops after a while during normal copy cycle to add toner. Replaced the developing unit (per Kyocera tech support) and ran U130 and U131 still the problem with it stopping and adding toner during just regular copying.
          • kuby
            • Oct 2007
            • 1400
            Ran U130 and U131 again per Kyocera Tech Support and it is running now? Ran 900 copies and then 500 copies without a stop.
