swapping out a M5118 Kyocera TASKalfa 3500i FUSER UNIT
  • fshead
    • 2356
    HI
    I normally only do ricohs but a good accnt asked me to pop in a fuser unit and "main charge unit too".
    I had time to look at it but didnt change it as it was still working wth scuffed fuser rollers and i didnt want to force that rear side black release after pulling out the 2 set screws..
    Is there something I should know b4 going back?
    IS the charge unit just a pop in corona unit?
    THANKS IN ADVANCE
  • darry1322
    • Oct 2010
    • 817
    Re: swapping out a M5118 Kyocera TASKalfa 3500i FUSER UNIT
    Fuser has 2 screws holding the unit in (front, rear) and a black cover for the connectors with 1 screw holding that in. Unplug the two connectors and pull the unit out then install the new unit.
    The charge roller just slides into the drum unit. Don't even need to take the drum unit out.
    Maint Mode 930 to reset the charge roller counter.
    Maint Mode 167 to reset fuser counter.
    • fshead
      • 2356
      thanks
      is the black cover near the screws?
      Are these pretty solid machines?
      The only kyoceras i did in the past were some 40cpm printers .
      • darry1322
        • Oct 2010
        • 817
        Originally posted by fshead
        thanks
        If it's still there, it's just a cover for the wiring and has 1 small screw to hold it in place. Right above the rear end of the fuser unit.
