IB-51, KFS Gateway error "Failed to send data with Enhanced WSD over SSL"
  • dschultz31
    • Aug 2018
    • 33
    We have a TA-3051ci with only a IB-51 wireless card. I called hotline and the IB-51 will not directly connect to KFS, but he suggested Gateway but he wasn't sure if Gateway would work.
    I test setup the KFS Gateway in house to verify it would work and pickup our machines. It worked perfectly. We don't have an in house IB-51. I then installed it at the customer location and received a failure message in the logs: "Failed to send data with Enhanced WSD over SSL" So the machine doesn't register.
    I had only a limited amount of time at the customer and will be heading back next week, so I'm wondering if the enhanced wsd over ssl in the Protocol section of the IB-51 command center is default off? I'm assuming turning it on, if off, would solve the problem?
    Thanks.
  • kuby
    • Oct 2007
    • 1400
    Re: IB-51, KFS Gateway error "Failed to send data with Enhanced WSD over SSL"
    If you are using KFS and input the customer code in the machine you do not need to load the Kyocera Gateway on a computer.
    Add the customer to KFS. It will give you a code. Setup the machine at the customers location and log into the machine thru the IP address. Make sure you have the correct IP information, gateway, domain etc. Go to Remote Services and turn it on and it will ask you on the Setting tab https://rfs-us.kyocera.biz and then input the customers Access Code in. The machine should show up in a few minutes in KFS.
    • dschultz31
      • Aug 2018
      • 33
      So I tried that originally but it comes up with no network connection when I try to register. It only has the IB-51 and no LAN cable.
        well if it has no Cat45 cable how do you expect it to connect to anything ?
        • darry1322
          • Oct 2010
          • 817
          I would guess through the IB-51 wifi connection.
          These wifi add-ons are kind of peculiar. Maybe the machine can't use this network connection to communicate with KFS. Just guessing though. That's the first thing I'd try to verify through tech support.
          • FriendlyTech
            • Jan 2018
            • 30
            IB-51 is a pain, I refuse to use them. Typically I get something like this https://www.amazon.com/TP-Link-Wirel...eywords=wr802n
            which I realize doesn't help you in your case as you don't have a spot for a network cable.
            • dschultz31
              • Aug 2018
              • 33
              • dschultz31
                • Aug 2018
                • 33
                Originally posted by FriendlyTech
                IB-51 is a pain, I refuse to use them. Typically I get something like this Robot Check
                Your wifi AP is a great idea for the future. This customer has wifi and I could use this AP to connect to the MFP's LAN adapter. This is the first time using the IB-51, we probably would have gone a different direction knowing that KFS doesn't play nice.
                  • 30158
                  May not be a card issue could be a router issue. Ask Kyocera what port it uses and than use port forwarding in the router
                  • tmaged
                    Owner/Service Manager
                    • Oct 2008
                    • 1880
                    I would say it won't work. Any machine that CAN connect to KFS on it's own, will only do so once when installing the gateway. After that, the machine has to connect direct. Go back in & look at your machines & KFS and they'll now be connected directly, if they are capable of that.
                    As Friendlytech suggested, we use the the Buffalo brand wireless bridge. Have been using bridges for about 10 years with very little problems.
                    Hope that helps !
                    -Tony
                    www.dtios.com
                    Become a fan on Facebook
                    • GeneOR95
                      • Feb 2018
                      • 161
                      Since this model came standard with a network connection port I have to ask what happened to it as it is an integral part of the machine. Or, is the problem that they do not have a network drop for the machine?
                      • dschultz31
                        • Aug 2018
                        • 33
                        There isn't a drop to this side of the building.
                        • GeneOR95
                          • Feb 2018
                          • 161
                          They will have to bite the bullet and have a drop run.
                          • dschultz31
                            • Aug 2018
                            • 33
                            Update:
                            I haven't been back to the original customer's location but I did purchase and setup the TPwifi link from Amazon at a different location. Works as advertised!
