Scan error 7100
  • FWITIW
    • Oct 2017
    • 14
    Scan error 7100
    We have a 3212i that they use to scan a lot. On big runs it will come up with a 7100 error. I am assuming that it is a memory code, but I have done firmware, and put in a new hard drive. The ram is not expandable. Anyone else ran into a 7100 scan error? Thanks.
    • 23007
    Re: Scan error 7100
    Scan to email? Perhaps you're exceeding the attachment size limit? Perhaps you could try monochrome instead of color scans, 200 instead of 600 dpi, less pages, etc.?
    • Santander
      • May 2009
      • 768
      Re: Scan error 7100
      Is the 7100 error a C code? There are no error codes in this model that display a 7100. Are you scanning to a folder via SMB, scan to email? Had a case a week or so ago where the network folder was limited by network IT as to the size of the file being stored. I would check with IT as to the file size allowed and if the folder has a storage limit on it. If scanning to email, is the email server on site or in the cloud as with MS 360? Have seen some weird errors with MS cloud email servers.
      • FWITIW
        • Oct 2017
        • 14
        Re: Scan error 7100
        Sorry guy's, SMB scan to a folder at 200 DPI. IT said there settings are OK but we all know how that goes. The 7100 doesn't come up as a C code, just a system error.
