Koycera 5052i error codes C6600, C6700 and C2300
  • copyalbania
    • Aug 2009
    • 165
    [Error Code] Koycera 5052i error codes C6600, C6700 and C2300
    I have been working on a Koycera 5052i with error code firstly c6600, c6700.
    I have seen some threads here and i check and oiled the gears that drive the fuser and everything seems ok,i checked and oiled and then i reset the error code the machine starts the fuser got warm also moved so the gears were ok it seems but than showed error c2300?
    Any help please any idea?
  • pbe@doe.com.au
    • Oct 2019
    • 2
    Re: Koycera 5052i error codes C6600, C6700 and C2300
    i had a similar issue with a kyocera 2552ci
    turn out to be the fuser belt ends had come undone and were causing the c6600 error but when you removed the fuser unit it all looked ok
    once the belt was replaced the error disappeared
    Dont know if this will help you or not but check the actuators that rotate with belt .
    • craigster
      • Apr 2016
      • 201
      Just replace fuser, I think they are on the 3rd version of those
