kyocera 5050 laser code C4000
  • Tom
    • 344
    I've had quite a few of these in the field over the years and never had a laser problem till now. Replaced the laser and reseated all connectors but still getting intermittent C4000 codes. Turn it off and back on and it usually goes away for awhile. I'm starting to think board related, but curious if anyone has had this issue before I start swapping boards.
    • 23007
    Re: kyocera 5050 laser code C4000
    Laser codes on Kyocera are almost always a high voltage leak or a doorswitch issue. =^..^=
    • mtcchuck
      • Oct 2016
      • 50
      x2 MC Assembly or door switches
      • Tom
        • 344
        Thanks guys, after you mentioned it I remembered having a door switch problem years ago that was giving a weird code. Must be getting old, I didn't remember. I wish I could back up all my decades of knowledge in the cloud and pull it out back out when needed. I'll give it a try today, if I remember correctly it was the push in door switch that was the problem, not the lever switch, but I'll bring both.
