Kyocera-Mita-cs6002i prints only blank pages after new MK installed
  • spickett
    • May 2018
    • 2
    [CQ] Kyocera-Mita-cs6002i prints only blank pages after new MK installed
    Hey,
    Has anyone had any issues with putting a new MK on these machines? The machine was working just fine, before MK was installed. The only reason for changing it is that the MK counter had reached its life limit. I went in this morning and printed my reports off (they were nearly perfect), then started replacing MK. After all new parts were installed, I ran the adjustments that are outlined to be done. I also updated the firmware. When i tried to rerun my reports everything came out blank. I checked to make sure, the gray tab on the developer was pushed in completely. It was, I then tried running developer refresh a couple times. I still came up with blank pages. I tried replacing toner ,because the one in the machine was about ready to be changed anyway. Nothing worked. I'm showing that the MK 6335 will work but, the developer has a different number than what the machine did originally. Could that be my issue? Any help is greatly appreciated.
    Re: Kyocera-Mita-cs6002i prints only blank pages after new MK installed
    Originally posted by spickett
    Hey,
    did you use the PROPER MK?
    sounds like not the case.
    • lees
      • Apr 2011
      • 95
      According to what I see, it takes a MK-6325.
      • JR2ALTA
        • Feb 2010
        • 2033
        Does the old dv unit work when you put it back in? If yes, it's a problem with the dv unit.
        Did you remove the protective sleeves in the mag roller?
        • ntbann
          • Jan 2012
          • 628
          Did you install the new parts with the power on?
          • Luther
            • May 2006
            • 682
            did you run u130, and go thru each step in u952? sounds like the dv unit is empty, so the dv has to he filled using u130
            • spickett
              • May 2018
              • 2
              Thanks guys for the help. Sorry I'm just now getting back with everyone. It was the correct MK , they made an adjustment to the part number. There was a bulletin on it in the forums on copystar's website. I found my problem to be a small piece of packing material was stuck in the developer. It kept the gears from meshing together, in turn not letting the developer turn, I just didn't see it the first time I was there. Sometimes you just need to take a break ,then take a second look.. Thanks again for the help.
