KM4035
  • copicatt
    • Nov 2008
    • 366
    KM4035
    Have one of these that was scanning to email fine until the other day when they said they had network issues. It now goes through the motions as if it completed the scan but it never shows up in email. The log on the scanner shows and error 23 or 32. Pretty sure they said 23. Is there a manual that shows these scanning error codes? Don't see it in any of my manuals, but it may be in there somewhere. Thanks!
    • 23010
    E023 = The SMTP server is not operating properly.
    If the regular email seems to be working OK, I would check that you are configured to the right SMTP IP address or host name.
    E032 = During Scan-to-PC operation, the hard drive on the destination computer ran out of available space.
    I think it was probably the 23. =^..^=
    • copicatt
      • Nov 2008
      • 366
      You are the man! That helps alot. I'll check on that info. Is this in a certain manual where that I can show the customer? Thanks
        • 23010
        They don't cover this subject very well in most manuals. I also don't have much direct experience with Falcon IIs.
        The easiest way to configure the scanner is through the web interface. Look in the scanner defaults for "SMTP address or host name". Sorry I can't be more specific than that. =^..^=
        • B0265
          • Jan 2007
          • 718
          You can find the error codes in the Scan Sys operation guide.
