FS1118 c6400 error
  • dans
    • 5
    FS1118 c6400 error
    Hello
    can somebody help me to reset C6400 error?
    I try to enter in service menu (with 10871087) to reset field U163 but the machine don't want to enter in service menu....
    I spoke with one person and he tell me that I must rewrite the eeprom on this machine. When I read the eeprom (24C128) I see this is empty (only FF FF ...)
    Can somebody send me a eeprom readed from a fully functional machine?
    Thanks in advance
    dans
    • 23008
    Looks like a US CS-1820
    If it's the same, try this:
    Press System Menu/Counter, cursor down to Select Service, press & hold Start-#-Enter.
    That will get you into service mode. The best thing that you can do first is buy the friggin manual. These maintenance modes are not that intuitive.
    • kyoceradude
      The Great Gazoo
      • Aug 2006
      • 442
      You will first need to turn off and unplug, open top cover, then turn on and follow above directions.
      My mission here on Earth is to help all you Dum-Dums!
      • dans
        • 5
        I tried that as you told me and look what write on the screen:
        [C6400] Detail=0000 osmwPROC
        (osmwPROC)
        FILE=
        FUNC=
        LINE=
        I don't know what mean..
        thanks
        • dans
          • 5
          As you tell me I can enter in user menu, but when I close the top cover I give again C6400 error...
            • 23008
            It sounds like you didn't understand the part about "Buy the friggin manual....".
            A manual is a tool. When you go to work do you borrow your neighbors car? or borrow your neighbor's computer? I don't think so.
            Can you at least pretend that you're a professional?
            • dans
              • 5
              Finally I enter in maintenance menu, reset field 163 and the machine work again!!!!
              Thanks a lot for your help!!!
              sorry for the inconvenience
