F041 code on a 250ci
  • Tonerkiller
    • Oct 2012
    • 669
    I have a 250ci that came up with a F041 code. We replaced the ISM PWB and updated the firmware, we still have the code. Anyone else had that?
  • nathicana
    • Aug 2008
    • 335
    Re: F041 code on a 250ci
    I had that code on a 5501i. I ended up replacing the whole scanner assembly which fixed it :
    My theory is that the LED lamp pwb that provides power to the exposure lamp went bad and took out the isc board.
    On a 250ci the lamp board (called the inverter pwb) connects to the ISM board. I would try the inverter board and ISM board at the same time.
      • 23010
      The manual shows Main PWB as first choice. =^..^=
      • Tonerkiller
        • Oct 2012
        • 669
        Yeah, I seen that. The main board is almost never the issue.
        We replaced the main board, (On a 250ci the lamp board (called the inverter pwb) connects to the ISM board. I would try the inverter board and ISM board at the same time.) Replaced the bracket that holds both these boards. Now like I seen in a previous post, we are replacing the entire scanner assy. I am glad we have a bunch of these in the junk pile. I will post the results.
