Machines show offline on KFS then coming back after a power cycle
  • r3d343420
    • Aug 2012
    • 59
    [Misc] Machines show offline on KFS then coming back after a power cycle
    Anybody else having issues with machines dropping off KFS? After the last firmware update that addressed the F and C errors associated with KFS, I thought we were going to have better luck with KFS. It seems as though in the last few weeks we have had machines dropping offline with no errors. If we are lucky we can have the customer power cycle the machine and it comes right back up. My main issue is when we have to drive to each location and do it ourselves. It is across the board as far as models go and there dosent seem to be a rhyme or reason behind it. The machines we power cycle dont seem to have the issue again, as far as I can tell. But every morning I check KFS, low and behold, there is a new set of machines that show offline.
    Really starting to become annoying as we use KFS frequently, and it seems like when they "fix" one issue, another arises.
    Re: Machines show offline on KFS then coming back after a power cycle
    Originally posted by r3d343420
    Anybody else having issues with machines dropping off KFS? After the last firmware update that addressed the F and C errors associated with KFS, I thought we were going to have better luck with KFS. It seems as though in the last few weeks we have had machines dropping offline with no errors. If we are lucky we can have the customer power cycle the machine and it comes right back up. My main issue is when we have to drive to each location and do it ourselves. It is across the board as far as models go and there dosent seem to be a rhyme or reason behind it. The machines we power cycle dont seem to have the issue again, as far as I can tell. But every morning I check KFS, low and behold, there is a new set of machines that show offline. Really starting to become annoying as we use KFS frequently, and it seems like when they "fix" one issue, another arises.
    from what I understand.. this is quite common of a problem.
    • tmaged
      Owner/Service Manager
      • Oct 2008
      • 1901
      I've noticed the last couple of times (11/15 & 12/5) that's when the majority of the offline machines went offline. I'm guessing since the time is common across different customers, etc. that Kyocera did updates to the KFS servers & those devices didn't connect. Yeah it's a major pain having to babysit the system. Especially when you need them online for auto toner ordering & billing. Having to call customers to reboot their machines makes us look bad IMO, even if there's nothing we can do to remedy the situation.
      Hope that helps !
      -Tony
      www.dtios.com
      Become a fan on Facebook
      • Dan J
        • Oct 2011
        • 25
        We are having the same issue. It is getting old fast!!! Some of our customers are over an hour away so it cost us money to send technicians out to reboot machines or get meter reads.
        • Tonerkiller
          • Oct 2012
          • 669
          Same here. They need to get their shit together!
          • ntbann
            • Jan 2012
            • 632
            Us too! Just updated firmware using kfs and that machine dropped off!
