Can unwanted faxes be blocked on a Kyocera 406ci with fax unit?
  • vsluggo
    • 23
    [Misc] Can unwanted faxes be blocked on a Kyocera 406ci with fax unit?
    My dental customer is receiving too many junk faxes and wants to call block them. Is there a way to not receive unwanted faxes? The fax is on all the time, so unplugging it isn't an option, and they send everything to email is " too much work" for them to do. Dontcha love it!! 40 plus years in business and I learn and see something new everyday
    Re: Can unwanted faxes be blocked on a Kyocera 406ci with fax unit?
    block the phone # being sent from...
      • 30300
      Forward fax to email or folder
      Nope you can't block them. Only problem with fax forward is no output means no money.
      • darry1322
        • Oct 2010
        • 817
        There is an RX restriction setting that allows you to set a list of permitted numbers or a list of rejected numbers. Check out the Fax User Guide for that model.
          • 30300
          Yep its there but in 40 years NEVER used it. Only permitted numbers than you'll get calls can't receive faxes
            • 23009
            It works, but there will be a lot of complaints about non-whitelisted numbers not going through. You'll be there constantly editing the list. =^..^=
