Copystar 2635DW Popping Every Paper Exit
  • Happy Copier
    • Mar 2019
    • 49
    I attached a video of it popping and hopefully you can view it, but right before the paper rest in the exit tray there is a pop, what do you think it is? Thank you so much for any help!Tapatalk Cloud - Downlaoad File 42719.mp4
    Sent from my SM-G930V using Tapatalk
  • Happy Copier
    • Mar 2019
    • 49
    Re: Copystar 2635DW Popping Every Paper Exit
    Well we decided to order a new fuser. You can barely turn the gear in it so we are thinking that the popping is a gear slipping. We will see when the fuser comes in the mail....
    • GIUBOSS
      • 1436
      you checked the gears and the exit section if it has breaks it seems a problem in the paper exit. In multi-copy jamming? if it were the fuser it should jam.
      • JR2ALTA
        • Feb 2010
        • 2033
        It's the fuser. Was a post on this but I can't find it
        • GIUBOSS
          • 1436
          1e5d0175a2c07ed8754a572b58f0c50e.jpg ti riferisci al bollettino
          • GIUBOSS
            • 1436
            1e5d0175a2c07ed8754a572b58f0c50e.jpg is this ?
            • JR2ALTA
              • Feb 2010
              • 2033
              Originally posted by GIUBOSS
              [ATTACH=CONFIG]44584[/ATTACH] is this ?
              No but that bulletin is important as well. I was referring to this thread https://www.copytechnet.com/forums/k...ht=#post940297
              • Happy Copier
                • Mar 2019
                • 49
                It was the fuser. Thanks for the help
