5052ci Repetitive Yellow
  • Happy Copier
    • Mar 2019
    • 49
    Check out that repetitive yellow, looks like it's diagonal, comparing it to the repetitive defects gauge and it says it's either charger roller or sleeve roller. About to go check out, just wondering what ya thought....
    Sent from my SM-G930V using Tapatalk
  • ntbann
    • Jan 2012
    • 628
    Re: 5052ci Repetitive Yellow
    Looks like yellow DV unit to me. If it is the DV unit it might have taken out the drum also.
    • Happy Copier
      • Mar 2019
      • 49
      Yeah we are going to replace both of them, thanks for the response
      • tmaged
        Owner/Service Manager
        • Oct 2008
        • 1888
        Those are auger marks from the DV unit.
        Hope that helps !
        -Tony
        www.dtios.com
        Become a fan on Facebook
        • JR2ALTA
          • Feb 2010
          • 2033
          It may not be the yellow. Those diagonal patterns result from the LACK of developer. So in a composite color print out you may see yellow stand out because of missing C-M or K.
